Re: stoopid question - how to change bulb in SF e2
I just went and got my E2e from the glovebox and opened it up. The lamp assembly drops right out. I don't see how it could hang up on anything unless it was glued or melted in there. Does yours rotate freely? If not, the bulb heat may have melted/swollen the plastic collar in the reflector bore. If this is the case, grab the base with a needle-nose plier and twist until it turns, then carefully pull on it as you twist. It should come out with no damage to the reflector.
Hope this helps.
