Robocop
Moderator, *Mammoth Killer*
I have both the new M1 and M3 Pelicans and both have horrible rings on the outer edge of the corona.
I was playing around with the reflector attempting to swap out the factory reflector and noticed that when I removed the bezel and left the factory reflector in place the beam was much better.
It seems that the artifacts and distortion is due to the bezel or even the o-ring or lens. If anyone has one of these will you try to remove the bezel and shine it on the ceiling with just the reflector in place. I am curious if this is unique to my lights.
I am not sure how to repair this problem as the only solution seems to be a different bezel and not the reflector as I first thought.
