Bronco
I received my HDS Ult 60 from the good folks at the Battery Station today and I was wondering if the following sequence was possible to set up:
--From off, click once to turn on to factory primary setting (10 lms?)
--Then, while illuminating at primary setting, press once for maximum setting but have the light remain at max setting after button is released
--Then, while illuminating at max setting, press once to return to factory primary setting
--Finally, while illuminating at factory primary setting, click once to turn off
Thanks in advance.
Thanks in advance.
