Looking at the U2 review at flashlight reviews.com, there is a nice table comparing throw, overall output, and runtime on the various output levels. Some data points are included below with the Arc AAA as reference...
Level / Throw / Overall
1 / 43.42 / 55.00
2 / 32.86 / 32.50
3 / 25.10 / 17.82
4 / 18.03 / 9.42
5 / 12.84 / 4.83
6 / 8.25 / 2.25
Arc AAA / 7.28 / 5.20
The thing that jumps out is that the U2 appears to be very much a spot at lower outputs with the throw being "higher" by a factor of 3+. By the time you get to level 4, the factor is down to 2. By level 2, throw and overall output are equivalent. In comparison, the Arc AAA at output comparable to the U2 on low has throw and output numbers roughly equivalent.
I know these numbers are just for reference, but in use does the light act as indicated above: focused "spot-like" at lower levels moving towards more "flood-like" at higher levels?
Thanks,
Matt
1 / 43.42 / 55.00
2 / 32.86 / 32.50
3 / 25.10 / 17.82
4 / 18.03 / 9.42
5 / 12.84 / 4.83
6 / 8.25 / 2.25
Thanks,
Matt
