EternaLight EliteMax...BRIGHT for a \"4-banger\"!
I recently purchased an EternaLight EliteMax in B/S/T from T I N (GREAT, timely service, BTW...Thanx, Ray!). It's been quite some time since I've purchased any 5mm LED lights since becoming a "luxeon-fiend". To me, the output just seemed to be "anti-climactic" when compared to luxeons. But I've read a lot of good things about the EliteMax, and it struck me as being a great all-around utility light...so I said WTH, and decided to go out on a limb and get one. As far as 5mm lights are concerned, this thing is extremely bright, especially when you consider it's only a "4-banger"! I did a side-by-side comparison between the EliteMax and my SL Propoly 4AA 7 LED, and the EliteMax is noticeably brighter, and has MUCH better tint! I run my SL on 3 lithium AA's and a dummy cell (the output is just as bright as running 4 alkaline AA's, and the run-time is actually better). Next, I compared the EliteMax to my Night Cutter 5 LED Sport Light with fresh 123 cells...this wasn't even fair; the EliteMax blew it away! I read somewhere that TechAss was using 26Kmcd LEDs in the EliteMax. Well, I can neither confirm nor deny that...all I know is that it beats the hell out of any other 4-banger I own, and even out-shines my SL 7-banger! Color temperature of this particular light is quite cool, as is typical with most 5mm LEDs, but it has FAR less blue in the hotspot than the SL...VERY pleasing output/color! And "cool-factor"...anybody who already owns an EternaLight knows it has a GREAT "cool-factor"! With the very comprehensive instructions that come with the EliteMax, it's incredibly easy to use; and the fact that you can switch from regulated to unregulated for longer battery life is a big plus (personally, I MUCH prefer regulated, but having the option to switch is very nice indeed!).
Anyway, if you've "sworn off" 5mm LED lights as I did since discovering luxeons, the EliteMax is one light that will definitely help you remember just how useful (and bright!) they can be. One of the biggest "issues" that most folks seem to have with EternaLights is that the "back-wash" from the exposed LEDS can be quite distracting. I simply hold the EliteMax sideways instead of flat, and it becomes a non-issue. I find that the EliteMax is actually more comfortable to hold and use in this manner as well. I'm quite pleased with this cool "gadget"! IMHO, even if you are a luxeon phanatic, you'll still find the output of this light to be VERY adequate for most tasks, and the extended run-time on the lower output settings makes it a great emergency light! FYI...
PJD
PJD
