pcmike
How viable is Teflon tape on a Scorpion (or any light) on the threds instead of "lubing" (I still have no clue what you're suppose to use to "LUBE" a flashlight) the threads? I've also thought about using teflon tape to "stiffen up" the focus (even though it doesn't really need it right now). If anyone is using teflon tape on a flashlight, how hard is it to remove (e.g. does it rip up easily and make a mess to remove)? Thanks for the advice guys...
Also, if anyone knows is the spring in a Scorpion meant to be easy to remove? I inadvertedly thought the replacement bulb was somewhere beneath the spring (before I read the manual) and gave it a few tugs. It never came loose, but I'm just curious if its even meant to be able to be removed or did I possibly damage something with my tugging? Light still works fine..
