goldenlight
I finally broke down and bought a Peak Matterhorn 1 LED snow Ultra power lug model.
And I think it's a superior light. I'm probably going to get assassinated for this, but that's my opinion, and I'm sticking to it.
It's virtually identical in form to the Arc-AAA rev 4 Premium; it has the slightly larger diameter head, and is about 2 or 3 millimeters longer.
It cost $38.84 delivered (in 2 days) vs $45.99 for the Arc Premium, delivered sometime next month (?).
The main difference is the beam quality. Let's face it, the Arc-AAA rev 4 Premium has a butt ugly beam.
I mean chimpanzee butt ugly.
It has an angry blue 'hot spot' shot through with **** green. :sick2:
The Peak Matterhorn 1 LED snow Ultra power lug model has a smooth, very slightly blue, very, very even, beam.
Output appears identical to my eyes, in every test I could think of (shine at wall at various distances, bounce off ceiling, etc.) I have no instruments to test this. Both lights had new Energizer lithium L-92 AAA cells.
The Peak does have two fairly dim rings in the outer edge of it's beam. It took me awhile to figure out why: the snow LED is much more deeply set into it's little reflector than the Arc-AAA is. It's easily set twice as deep, around 2-3 mm deeper. I believe the faint rings are artifacts due to LED reflecting off the edge of the reflector.
My only complaint about the Peak Matterhorn was that the head was quite stiff to turn it on; so stiff it was virtually impossible to turn on with one hand, even after lubricating the O-ring with a light weight silicone lube.
A trip to the hardware store, and 49 cents later, and the head turns easily. I used a smaller diameter O-ring, but with a bigger cross section, and now it's perfect.
I don't know about run-time comparison between the two lights, and frankly, I don't care. I spend the $2/ea to use the lighter weight, and superior output Energizer lithium L-92 AAA cells. I use this kind of light frequently, but intermittently. A battery can easily last 6 months or more for me, so run time difference are simply not important to me.
Back in 2001 (had to check the archives....) when the Arc-AAA first went into production, it was practically a miracle. Small, reasonably bright, and most importantly, it didn't use those expensive and short lived coin cells. Later, it got HA, vastly improving it's durability when attached to a bunch of keys.
Arc LLC had been a massive inovator in the small LED flashlight world, making numerous 'firsts', which have been copied by a vast number of other manufacturers.
Well, it's 2005, and IMHO, the Arc-AAA rev 4 simply hasn't kept up with advances in 5mm white LED technology. The Arc-AAA rev 4 Premium looks very badly overdriven, while the Peak's snow LED is in a whole other, and vastly superior, league.
I cannot understand why the Arc-AAA rev 4 Premium doesn't use one of the many better 5mm LED's currently available.
The Arc-AAA rev 4 Premium is still a very good little light; it's just overpriced, not currently available, and Peak currently makes a better product for less money, IMHO.
Nothing would make me happier than to see the Arc-AAA rev 4 Premium get an improved emitter. It's my opinion that it should have had one from the beginning. But until the Arc-AAA rev 4 Premium DOES get an improved emitter, I'm just not going to recommend it, while the Peak 1 LED AAA Ultra power snow lug style light is available.
Don't get me wrong: I LIKE Arc products, and I'm looking forward to new introductions; I just hope they are better than the Arc-AAA rev 4 Premium
Flame away! :devil: :nana:
