juancho
I have two 18650 protected cells and put that in a 2 C (had to drill some material in the tailcap) and use that for a while with a Carley 612 bulb.
Until today when I put a kiu ceramic socket and a WA01274 bulb.
I didn't light up so I tried another, I tried cliking double and triples and even four times nothing.
Just for the heck of it I tried a 01160 but I knew will be too much current demand, it was, it tripped the protection of one cell.
What is going on and what bulb will work with these batteries??
My meter blowed a fuse and can not check voltage but the needle in my battery tester (1.5) jump when I touch the probes to the kiu socket pins' openings.
Juancho
Juancho
