I just installed a wiz2 converter board into a 3 nimh AAA lux3 light. It doesn't work anywhere near like I thought it would. It runs fairly bright (but not near as bright as directly driven-maybe 1/3 as bright) for 1 min, then starts to flicker really bad, and gradually gets dimmer. After about 3-4 min. there is no useable light, and the led is just barely lit up. I tried running a lux 1 with the same results. I don't know if the converter is bad, or if I hooked it up incorrectly. I also noticed that the lux3 is not as bright as the lux1, no matter how it is driven.
