jashhash
I am making a prototype of this light and just wondered what you guys think. Should I make a production run of these?
The specs of the prototype:
Body made of Mesquite wood.
The tailcap is made of mahogany
The lense is a 32mm borofloat lense. The lense is held in place using Neodymium magnets.
The tailcap is the switch, each 90* turn causes 3 different brightness levels as each emitter is switched on [off], [80], [160], [240] lumen settings. The tailcap is held to the body using neodymium magnets.
battery is a 18650 Li-Ion battery held in place with Neodymium magnets.
emitters are 3x 3 watt CREE X-Lamps.
The reflectors are 17mm IMS reflectors.
Run times expected for low, med, high: 120, 80, 40 mins.
Forseeable downfalls:
I'm still not certain what driver circuit to use.
The current design is not water tight, I would like to make this at least survive a (Small) dunk.
the 240 lumen setting may run a bit hot.
Dont get this thing too close to magnetic storage media such as VHS tapes and flopy disks.
Cost: $200
Including battery and charger: $220-250
If I made a production run would anyone be interested?
I have a few questions before proceeding with this prototype:
Does the cree 3 watt LED work with the 17mm IMS reflector?
Assuming my battery is a 18650 Li-Ion What converter should I use to run a 3 watt cree?
Can I run three of these cree LEDs in paralell off one converter?
Cost: $200
