balazer said:
thesurefire said:You might consider a modded mag, with an nflux and say 3x lux III's. 8 levels, and 200+ lumens
Did I mention they are less then the U2 The only con is they are a bit bigger.
Then look at the "overall output" chart under the link that I posted.Xe54 said:Yes, I am interested in actual total lumen output first and foremost, as I often use a flashlight as a room illuminator by hitting the ceiling. Beam throw is something I'll think about after finding the lights with what would be more appropriately termed "highest lumen output."
The_LED_Museum said:The Tri-Star Phazer is the brightest LED flashlight in current production that I'm aware of.
http://ledmuseum.candlepower.us/third/tsp.htm
balazer said:Then look at the "overall output" chart under the link that I posted.
Xe54 said:I just wonder why since Lumileds indicates Luxeon V can put out 120 lumens, why something like the SF U2 doesn't fully exploit this? I suppose it is because running the LED at that output would result in a mediocre lifetime, and thermal management may be nearly impossible in such a small package.
