DFiorentino
Just thought I'd share this with you all since I'm still giddy about it.
I had originally been reluctant to buy the Thor as I thought "what am I going to use it for", but bought it anyway because it was relatively cheap and had high :wow: factor. Well, that wore off fast, so long story short, I now have an HID equipped spotlight .
The H4 HID bulb I used originally had a low beam (H3?) bulb as well as a glare sheild that I removed. (FYI: I'll most likely be posting the companion bulb/ballast for sale soon.) The bulb was in desperate need of spacing however. So, I cut a spacer ring from a steel pipe and epoxied it to the bulb base. I also used the ring as a way to mount the bulb in the flange with a few screws. It looks ghetto, but it is very functional and secure.
The spacer ring...
The ring fitment...
Epoxied to the bulb...
Whole assembly installed in reflector...
From the front...
:naughty:
Left: 21W HID 2MCP Vector, Right: 35W HID Thor
Thanks for looking.
-DF
The spacer ring...
The ring fitment...
From the front...
:naughty:
Thanks for looking.
-DF
