MillerMods
I've modified a Gerber Infinity and an MXDL using a raw lithium ion cell and a circuit that I designed to drive a 5 watt luxeon in the past. I sold the MXDL and got slightly less for it on ebay than it cost me to make it (The customer was very pleased and has continued to keep in touch with me, asking when I will make him a modified Gerber, he says he always carries the MXDL in his police bag). I kept my modified Gerber and went on my merry way, discouraged that there wasn't more interest in the MXDL mod. I have a feeling the host I chose was more to blame for the lack of interest. Although I haven't recieved my Fenix L1 yet, I know this flashlight will make a superb 5 watt host. 5 Watts is alot of heat to dissipate I know, but the Gerber, although very tricky to pull off (mounting the Luxeon and polishing the bezel and nickel plating it! eek, too much work) it worked out O.K. but no hot spot, just mostly a flood task light and it does make a great hand warmer in the winter time! The Fenix is slightly longer and the same diameter as the Gerber, I can't wait to mod the Fenix, it will be a perfect match with it's reflector. The larger LED chip in the 5 watt Luxeon will give a hot spot that is much larger than the 1 watt. I just want to see if anyone is interested or has any questions.
