Hey FrankW438, I'd be happy to write down the instructions and post them up here for a step by step guide to upgrading this light with a Seoul. It is really hard to mess up. In fact, a Sheriff's deputy friend just emailed me yesterday to see if I could get him a light like mine so I will be ordering a 3rd today and upgrading it for him. I could throw up some text for the upgrade later today and then take pictures and document the upgrade I do in a week or so. Strategos will not upgrade Typhoons by the way.
I understand Strategos/Blackhawk designed and created the Gladius but because they are only a marketing/brand managing group, they contracted with Insight to manufacture it. Somehow Insight was able to make it themselves under their own brand (the Insight H2X Typhoon) after some time through some poorly worked out contract. It has been a bone of contention between the two but it would appear that both are here to stay.
Insight sells the light already with the factory warrantied upgrade as the Typhoon 2 and does not offer upgrade services for existing lights. Strategos is the middleman for an upgrade service for the Gladius only and offers a 1 year warranty done on the work through them. Your existing Gladius lifetime warranty is null and void though. Last I heard, they were having turnaround issues on their upgrade service. Insight offers a lifetime warranty on their Typhoon 2 which has the upgraded Seoul LED in it already but I am unsure of the bin they are using. They advertise 170 lumens output. A U bin Seoul should put out around 200 lumens at the 975 mAh these lights run at.
So your options are:
1. Mod either light yourself and void your existing factory warranty but have 200 or so Lumens. It’s a solid mod and difficult to mess up. If you light works well before the mod, it will work well after the mod.
2. Have Strategos supervise the modding of your Gladius and void your lifetime warranty. You will however receive a separate 1 year warranty from Strategos on their work. There is a potentially long turn-around time for their service and it costs 60 bucks. They don't do Typhoons.
3. Buy an new model Typhoon 2 that already has the factory Seoul upgrade from Insight with a lifetime warranty for less than the price of an unmodded Gladius (about $165.00). Its factory advertised as having 170 lumens which may be conservative. Bin is unknown though is likely a T or U bin.
4. Keep your light as it is, knowing that you could have more than double the perceived output, a longer run time, and full water-tight integrity if you had the sack to choose another option. :laughing: You will still have the best UI of any flashlight ever created in my opinion.
I recommend option 1:twothumbs. If you guys want some step by step instructions to do the mod, I can post some up later today.
Hey Justin Case, I have been modding Typhoons but would assume that the Gladius has the same threadlock on the head. Luckily the two I have done have come off with just my hands, a bit of straining and bulging blood vessels in my forehead :laughing:. Strap wrenches have worked for other guys but I didnt have any that could grip tight enough on such a small diameter. Mine were for removing oil filters. Both of the typhoons I modded had threadlock for about 2 threads at the base of the head. Boiling in a zip lock bag didn't work for you? A heat gun used for stripping paint should do the trick. Just keep it moving and concentrate on the base seam. It shouldn't be a problem if you have an anodized Gladius as I have used a heat gun on that type of finish before without damage. If you have a older ceramic finished Gladius I wouldn't think that it wouldn't be an issue but can't speak from experience.
Fletch31
