Re: Panasonic NCR18650B
wait, so having a higher voltage rated battery, like a 4.35v ones, is better and perhaps yields more voltage available to the emitter when under load and at a lower capacity left in the cell? am I correct? does it matter if you only charged a 4.35v cell to 4.2 volts on a standard li-ion charger?
Hi tobrien. I think HKJ pretty much covered your questions. It's not so much the available voltage to the emitter, this is controlled by the driver limiting the current. It is the available voltage to the driver itself that is the problem.
For example, my primary interest regarding voltage held under load, relates to download's 8th run Pocket Rocket. This light draws close to 3A on high. It is also one of, I believe, only two lights made, with a driver that has a low voltage warning that kicks in at ~3 Volts.
To make matters worse, the light body is made from titanium, which is a poor electrical conductor. I've done a tailspring mod, ala M@g, to reduce the resistance in the light's electrical circuit, but still, keeping the voltage as high as possible is important to enable the light to run at the high level, as long as possible. As it is, an IMR 1600mAh cell will run the light almost as long as a 4.35 Volt Samsung 30A cell.
The lower levels are not really affected. In fact, the 30A cell will run the light at medium, or low, for a long time, after the warning kicks in on high, whereas the IMR cell is pretty much "done" at this point. The difference is that the IMR cell holds higher voltage under load, compared to the Samsung 30A, but runs out of steam much sooner, as it is only about half the capacity.
Dave
