Titanium tubing is used in industry where liquids and gases of a corrosive nature are a real consideration and must be addressed. There are certain acids and other chemicals which can be corrosive to Ti and obviously the spec on methanol is something engineers need to be aware of. I would guess that cautions as stretching as cleaning the threads with methanol could be brought up for most metals but the relevance needs to be factored in. Most corrosion situations also require a time factor and circumstances held in constant during the time period. I would be curious if Marduke could give an example of a cleaning agent containing methanol that actually would cause any noticeable degradation to Ti in the application of cleaning the threads where presumably after cleaning the threads the cleaner would either evaporate or be removed, the Ti would then quickly oxidize gaining its protective film and likely some lube then applied.
I am aware of a number of advantages to Ti that have significance and relevance to me. These advantages may have no significance or relevance to others. I would say that I am indifferent to bling but actually I have an aversion to it and see it as a disadvantage that needs to be overcome. Ceteris Paribus, I would be reluctant to own a Rollex Watch these days because of the bling associated. For starters, there are more accurate watches at a fraction of the cost and they are lighter by virtue of their Ti cases and bracelets! :nana: I consider my Luminox Titanium a reasonable case in point.
IMHO, the two most significant disadvantages to Ti, relative to use in flashlights, are cost and weight. For small runs, the high cost can be an advantage because the setup involved becomes a small proportion of overall cost and the much greater machine time required per part means a smaller run will take the same amount of time as a much greater run of say aluminum parts. Most shops have minimums and these minimums can be met with much fewer titanium parts than other materials.
As mentioned above in other posts, there is also the advantage with Ti of no need for adding a protective film as an additional step provided by an additional vendor. In the case of aluminum, it is expected to have an aluminum part processed with anodizing where a protective film of oxide is produced and covers the substrate. Ti oxidizes as soon as it is machined and will replenish its oxide layer anytime it is scared provided air is around to provide the oxygen. Ti has a self healing skin and although the healing may show some scars, it does heal and rather quickly! If cosmetic are important to you, you can easily apply cosmetic surgery to the Ti and let it heal in a surface texture that meets your cosmetic requirements. The good news is that cosmetics in regards to Ti are purely cosmetic and unnecessary beyond the look. Ti can face the bad world naked with no ill effects. I can't make the same claim!
