ahorton
- Joined
- Jul 22, 2008
- Messages
- 715
Re: Ahorton's sales (Lenses, screws, headlamps, connectors, Silicone grease and more)
I don't think the P60 format can transfer the heat well enough from an SST-90. So if it doesn't burn, then it will soon dim. Of course I'm sure you know this and will work around it as much as possible.
The thread on the spacer and pill should allow a bit of focusing range. I think the focal distance with the SST-90 is a little longer so you'll only have to unscrew it to make it work. Hopefully there is enough thread on both pill and spacer. I haven't done this myself so you'll have to experiment.
