I have updated my last post with the aspheric options. Here are an overview of the Dereelight line up.
Dereelight builds what is known as Surefire P60 clones. Most of their parts are interchangeable with the P60 and other clones.
List of flashlight bodies:
http://www.candlepowerforums.com/vb/showthread.php?186661-*-P60-Flashlight-List-host
List of flashlight modules:
http://www.candlepowerforums.com/vb/showthread.php?217252-P60-sized-led-drop-ins-(part-3)
You can put together Krillions of combinations.
Most people stick with one manufacturer to try keep things simpler.
So back to Dereelight.
Body types:
CL1H V4 - The original clone of the P60 with the body bored out to take 18650 and a LED module. (The original P60 can only take 2*CR123A and is incandescent.)
CL1H V4-NOHS - NOHS = no hotspot, a floody version.
DBS V3 - A big head version with a bigger reflector for more throw.
C2H - small CR123A version.
Javelin - 2AA version.
DA3 - AAA version. This is a keychain light and does not lego with the others.
CL1H-T/DBS-T - Dual mode tactical version. Head tight soft press gives you momentary. Head loose soft press changes brightness levels.
Optics:
Aspheric - The aspheric lens does not have spill so all the light goes down range. This provides the longest throw but you can not see a gopher hole or pothole in front of you and you twist your ankle if you are not careful.
NOHS - This is an optic that projects a very even circle of light. Useful for close in work.
Smooth reflector - This provides spot and spill. A spot for distance and spill for close in.
OP reflector - Smooth reflector tends to have artifacts or ringy beams. An OP reflector smoothes them out.
Modules and Pills:
A module consists of a reflector/optic/lens and a pill.
A pill consists of the electronics, heatsink, and LED.
Pills:
Dereelight identify the electronics as follows:
1/3 - S/M - (nothing)/M/T.
1 or 3 is the number of brightness levels.
S - single mode.
M - multiple modes depending on head tight/head loose position. See CL1H-T/DBS-T.
(nothing) - 1*18650 battery.
M - 2*CR123A/2*RCR123A/2*18650 (with battery tube extender). This is a pure buck circuit and needs 4+V to operate. A 18650 will work when freshly charged 4.2V to 4V but dims significantly between 3.9V to 3.6V. Dereelight does not recommend 1*18650 with these pills.
T - Tactical. See CL1H-T/DBS-T.
LEDs:
XP-E - Has the smallest die size, provides the tightest beam. OTOH it is the dimmest of the LEDs Dereelight uses. 0.9 mm * 0.9 mm.
XP-G - Can be driven harder than the XP-E to provide more light but is more floody. 1.4 mm * 1.4 mm. Dereelight is driving the XP-E and XP-G with the same drivers so your choose between them for beam types. ~300 lumens.
XM-L - The latest but the big die makes for a floody beam. Especially with other P60 types limited by the 26 mm reflector. Dereelight DBS with the bigger reflector compensates for this. 2 mm * 2 mm. ~700 lumens.
Tints:
Dereelight offers many LEDs with different tints. Cool white, neutral white, warm white. A thread showing the difference between the tints:
http://www.candlepowerforums.com/vb...arm-Neutral-Cool-White-BEAMSHOTS-amp-RUNTIMES!
