cyclesport
- Joined
- Feb 14, 2012
- Messages
- 676
Re: Eagtac Titanium Clicky
Sorry shelm, let me attempt to be clearer...
With 16340 3.7v Li-ions you loose regulation and go into direct drive. With the head fully tightened you can toggle back and forth with the clicky between turbo and strobe only. Loosen the head 1/4 turn (where most will leave their light 99% of the time) and you start at your first level, either low or moonlight (by tightening and loosening the head three times) and then by using light half presses of the tailcap go to second level, high, and then another tap gives you high again. *Sorry, but in my last post I said it goes from low/moonlight to turbo, but I actually meant high. In other words you loose medium and get two high's instead. Basically the light operates pretty much like it does with CR123 primaries its just that you loose medium and get two high modes instead + loose regulation.
And yes, to my eye the moonlight level seems to be the same with 3.7v Li-ions or 3.0v CR123's at approx less than a lumen, and low is approx 15 -20 lumens, but this is just a guess.
Don't mean to add to the confusion but when you get your new light the UI will become much clearer right away...it's very intuitive. Just be aware that with the XM-L emitter and such a small thin-walled light it gets very warm, very fast and as ET suggests, only run the light on high or turbo with freshly charged Li-ions no more than a minute or so for the first few actuations and no more than 3 - 5 minutes on high period. With 3.7v Li-ions there are simply limitations one must accept if you wish to prolong its life and avoid damage to the battery or emitter.
