Hi techjunkie,
i have seen this thread with your KD-V2 slave-mode technique few days ago and i find it quite interesting. I used this driver for a small single-xml once now and i like it. I am dreaming of building a small 7-XML-diving lamp as there is a really nice 7XML-board here in Germany. I would mill the LED-base like this:
7xml-board:
Due to this and the fact that i will use 7 18650er from panasonic all wired in parallel, i dont think that i will get heat problems as you described. Also my lamp will be watercooled as it is a diving-lamp. I would prefer a very simple construction, using a reed-contact to switch the lamp on and off. This will be easy possible if i can connect the LED positives directly to the battery as you described.
my question: is there more information available somewhere about your modification to the slave mode? Or could you maybe post some more pictures with higher resolution? How did you remove the needless parts from the board? Will there be problems when using 7 Leds?
THX a lot and regards from germany,
Henning
7xml-board:
Henning
