lexina said:
Do let us know when your A19 arrives, if the 3 168Bs works well with your Z3 plus 2 A19s.
As soon as I know, you'll know, in this thread. Of course, given that I've blown two G120 lamps by powering them hot off the charger, I'll let my 168B cells cool down for two days! Ah, the torture of waiting! No, wait: I'll have them already charged and cooled down. Whew!
lexina said:
I currently have a 6P and an A19. I have just ordered a G12 bulb from emillion and a King's Arm 1-cell extender. Finally, we will know if the King's Arm is compatible with the 6P!
The King's Arm will definitely fit a 6P. The only question is, can it hold AW's protected cells (R123A, 17500, and 17670)? The G&P is too narrow. Let's hope King's Arm didn't make the same mistake.
lexina said:
If so, I will have a 4-cell light (6P plus 2 extenders) on which I can fit the G12 which I believe is compatible with the normal tactical head of the 6P and Not compatible with the bigger mini-turbo head of the X12.
I have a G90 at home; I'll try to remember to test it with my surefire Z44 tactical head. If it fits the Z44, it probably fits the Surefire stock 6P head.
lexina said:
I am now considering if I should get a 4-cell light which, together with my 2 extenders, will allow me to run 3 of Aw's 17670s (hopefully, but no one has confirmed this yet) with the 12V bulb.
Judging by AW's specs, it should work, which will save everyone a heap of money in cells (two sets!) and charger. If you plan to charge the 17670 cells in a car, the only DC chargers I've found are the Wolf Eyes / Pila and Microfire. Each will set you back $27 to $30. If you don't get a spare set of cells, you'll probably want a spare charger. Remember: Once you charge these cells, you'll have to wait at least a day, preferably two, before using them safely with your G120 lamp. Can you wait? I didn't think so.
lexina said:
MY QUESTION is, should I get one of the generic 4-cell light such as the UltraFire12 from emillion or the equivalent from TradeDigit; or should I cough up for the X12 for the mini-turbo head and the Surefire compatibility? The generic 4-cells can be had for only about $35 whereas the X12 goes for $70 inclusive of shipping. Do you think the mini-turbo head is worth the doubling of the price? How much benefit can I expect, other than aesthetics of course since a 6-cell light with a tactical head looks odd, like carrying a length of pipe! Your opinion is much appreciated. Thanks, Paul.
Good questions. Arguments in favor of the Ultrafire: Cheap, slim, available in silver or black, glass lens, uses G&P's highest-spec'd lamp (according to the ads), clickie tailcap (reverse clickie). Arguments against it: Probably poor heat dissipation, no extenders available, and hence no way to use rechargeables with the stock lamp; can't use a turbo head; can't use Surefire tailcaps, can't use Surefire lanyard rings (head or tail), probably no rubber gasketing.
For me, the use of rechargeables outweighs everything else. Hence, only the Ultrafire 90 would be a good deal.
Yeah, a 6x123A body looks odd. But Mags come in similarly long length-to-width ratios.
The G&P boosts throw considerably. Even my 9V LEDWave, rated at 120 lumens could match my TL-3 in throw, BUT only in the very center of the the beam. My G120 lamp in the turbohead will beat a TL-3 in throw...but only in the center of its beam. The thing is, the turboheads are now priced so low, it would be criminal to pass them up! So get an X-3, X-4, or LEDWave Z-3; if the head is too large, spend $20 and get a Surefire Z44 tactical head and a new G&P lamp (for the tactical reflector).
