flash99dark said:
I just got my Z3 Targeter ledwave from Knifeoutlet.com and would like to know where I can get an extra bulb/assembly.
The only source for the 9V miniturbo lamp assembly is Digilight USA or its eBay dealer: $37 plus $8 shipping. If all you want is a spare lamp to screw into your miniturbo reflector, get the Digilight nonturbo lamp assembly ($18 plus shipping from the dealer) or the identical G&P 175-lumen nonturbo high-pressure lamp assembly from TradeDigit's eBay store (about $25 shipped, as I recall). Don't try using the standard G90, 105-lumen lamp in the miniturbo; I think the glass isn't long enough, and besides, a great stochastic reflector like the G&P deserves more lumens.
I have the turbo head model exactly like Paul's and not the one pictured on the Knifeoutlet website.
Yes, there are two varieties: Only one is roll-resistant. Likewise, there are two varieties of the tailcap: only one is oversize and roll-resistant. It's maddening, isn't it?
I have a Z44 head on order from Lighthound.com and already have A19 plus several types of clickie/non-clickie Surefire tail caps. I also have a few 168s & 150s Pila. I would like to run the 175 lumen with an option to put in the 12v 227 lumen with the A19.
I have tried to follow all of the various posts on this but I am a bit confused as the exact website and part number to 1. get an extra bulb/lamp for the 9Volt [mine says L2 on it) 2. get a 12v lamp to use as an option. Thanks ahead William[
You and I have pretty much the exact same set of options, William. In my commuting bag is a Z-3 with an A19 extender, Z44 head, Z48 tailcap, and Dililght 9V tactical (small) lamp assembly.
As I've written in this thread and elsewhere, I've lost faith in the 227-lumen/Pila solution. I've hot-flashed all three of my 12V lamps this way, although I did get four good cycles out of my final set. Four 3.0V lithium-ions can't power this 1.8A lamp; the 12V won't even work with thre eAW 17500 cells. The only CPFer who's delighted with his G&P 12V lamp is using three unprotected RCR123A cells. Evidently these cells will suffer enough voltage sag to keep the voltage safely below 12V.
P.S. I recently sold my Surefire M3 and must say I like the beam better on the Z3. I find it hard to belive that it is only 120L. The M3 had a lot of power but I did not care for the oval beam shape
I'm convinced that the 120-lumen lamp that comes on the LEDWave Z-3 is identical to the 175-lumen lamp that comes on the Digilight T9, Ultrafire G90, and G&P 9S miniturbos. It's maddening that the 105-lumen, 120-, and 175-lumen lamps are all labeled G90. The Z-3's beam is brilliant white, a color matched only by my RICO Alpha 9. Its tiny hot spot will outthrow a Streamlight TL-3. The 227-lumen 12V lamp essentially matches the Surefire P91 in total output; the P91's beam is more perfect in shape and uniformity but the G&P beam is about 20 percent wider--so wide that you won't be tempted to use a difffuser.
