[ QUOTE ]
capnal said:
I have to say I lean more towards wool. I have lots of jackets and outerwear. I have heavy cotton canvas such as the Walls and Carhart variety, but I also have things like Pendelton wool shirts and military Navy Pea coats. In fact, Friday I am picking up my new Filson style 82 double Mackinaw Coat, in forest green color.
I like the all weather performance of GoreTex, like if I think I might get rained on, for example, and I even bought a black jacket late last winter. However, for warmth, I grab the wool first thing. Filson says, "Because the Double Mack is wool, you'll stay warm even when wet, and you won't get overheated even during strenuous work." But I just don't like the idea of getting my wool coat all wet. I have also used Filson's garment wax to treat heavy canvas Walls coats to give them that same water repellency.
[/ QUOTE ]
Yup! Good ole Filson Double Mac. I've had one for almost 14 years now, and I used to wear it almost every day for 2/3 of the year. I am a big fan of Filson products, but the simple fact of the matter is that my Patagonia R3 regulator jacket, which is made from Polartec fleece, is superior to my Filson Double Mac in most ways. It is lighter and thinner and provides the same insulation value, and it is significantly more breathable, but also less wind-resistant to the same degree. And let me tell you: I have worn a completely soaked Filson Double Mac and it was
NOT fun! It may have provided
some insulating value, but it was not a lot, and it stayed wet and stayed wet. It's almost impossible to drive away all that moisture with your body heat. Plus, if you think it weighs alot dry (it does!) try it soaking wet. It is incredibly heavy.
My R3 jacket on the other hand is still not that heavy soaking wet and if you simply keep walking, hiking, or climbing, your body heat alone will dry the fleece.
One way the Filson is superior, though, is in it's toughness: walk through the underbrush and thorns and branches all you want; the Filson will be just fine. I'd be much more careful in a fleece jacket.
As for Gore-Tex, it isn't very breathable, but still, I much prefer it--or Marmot's "Membrain" which I own (cheaper)--to the totally non-breathable rain coats. Still, I agree that large scale ventilation through pit-vents and pockets and so on is the only real way to keep from building up sweat.
But what I'm most excited about is getting a soft-shell with Scholler Dryskin 3XCR (or whatever those alpha-numerals are). I'm thinking of getting a Cloudveil Serendipity Jacket.
