PCC
George, would you recommend this driver to power a red Luminous SST-90 emitter powered by two 18650? Yes, I'm planning the mother of all bike tail lights.
Finally got some time to finish assembling the protoype h6flex driver now that the h6cc is shipping and in use.
I'll continue to document the process in this thread as testing continues and then the steps to finish up the design for production boards.
cheers,
george.
So you can attach a low power led to tell you if your battery pack is dipping below your configured set point?
Awesome, just one other question about the mag switch and the switch solder points on the h6flex...I have three wires coming off of my momentary mag switch (pos, neg, and green signal wire), am I suppose to wire the signal wire and a ground to swa and swb? If so, which wire to which port? Thanks in advance!
Hey George, is it considerated safe and ok to power on without being attached to a thermal spreader? I got my driver soldered up but want to test functionality before I continue any further... I'm so stinkin' excited about this driver and my flashlight, it's not even funny!
As shipped the h6flex outputs a maximum of 1.4A (until you configure it via the menu system). As shipped it would be more than safe to run the driver without it being mounted on a heatsink. It would likely run continuously with no heatsink at 1.4A max output.
cheers,
george.
Quick question about the led and the voltage monitor, when using the formula to find what resistor you need to light your led, do you use the voltage the batteries rest at full charge to input into the formula or figure what the approximate voltage of your batteries about when you want the voltage monitor to illuminate the status led?
So (14.8-2.5)/.01= 1,430 ohms or something close by?
I got a blue led, 3.2v typical at 20mA with 16.8v battery pack...680ohms sounds right?
