SWB is electrically the same as the IN- on the driver, so wiring to the battery negative is electrically ok.
THE issue, is that with longer leads they can act as an antenna and spikes in the battery- wiring (due to transient load changes in the driver) can cause a misread at the SWA connection point. I provide SWB as a dedicated an electrically quiet point to wire a dedicated ground path to a remote switch.
So, in summary, using SWB is up to the end user and may be necessary for reliable operation depending on lead lengths from battery to driver, for momentary switch to driver. Since how folk wire things is out of my control, I've provided options for the end user.
My blanket recommendation is to wire the momentary switch to SWA and SWB - not everyone finds that to be necessary. Some folk using long lead lengths to the switch and running the switch leads close to power or LED output leads fine it necessary to add a capacitor (0.01uF would be sufficient) in parallel with the SWA/SWB connection points to perform as a filter for spikes that could cause the firmware to think the button has been clicked.
This is also applicable to all by flex drivers.
cheers,
george.
