the.Mtn.Man
- Joined
- Oct 3, 2008
- Messages
- 2,516
I mean it looks comparatively dimmer when set to the same output because the hot spot is less intense. If I put them both at max, then yes, the Rotary is quite obviously brighter.
This is starting to sound very tempting, and although I've been interested right from the start, the newer and more balanced beam pattern sounds better for me, and probably 95% of users since most of us really don't need throw as much as we need to see what's around us as well as in front too.I just did a "backyard walk-around" test and noticed a couple of things: first of all, the transition from hot spot to spill is a lot smoother than the older model high CRI (which uses, I think, a P4?) so it appears a more even brightness from edge to edge which makes for a really nice usable beam. But because it is floodier, it appears slightly dimmer overall than the high CRI, which I actually find a nice feature because even the high CRI's lowest mode seemed almost too bright in the middle of the night. Turning the Rotary on to full bright lights up pretty much my whole backyard (roughly 150x60 ft) and I can easily make out detail on the back fence, so it has plenty of "throw" for my purposes.
Thanks for the comments.This is starting to sound very tempting, and although I've been interested right from the start, the newer and more balanced beam pattern sounds better for me, and probably 95% of users since most of us really don't need throw as much as we need to see what's around us as well as in front too.
Nice little mini-review there Mtn.Man!
I must admit, the cool white tint is driving me a little crazy, especially after using high CRI for almost a year.
I have 2 now and still haven't hit the ringy jackpot, I've modded a few and none of them were anywhere near as bad as the one that Proflash got. While it's not the most perfect beam profile, I haven't had one in my possession that was worth chucking up. I will be performing some experiments soon, will post results if anything interesting is revealed.Anyone interested in modding rotaries? I am particularly interested in the adjustment of the reflector that someone was working on by shaving some of the body down so the bezel can sit closer.
EDIT: It was Bansuri
I've modded a few
Here's a how-to.Is it just a straightforward emitter swap without having to dig into things?
Me too. I use to say "my Ra" or "my Clicky" about mine I bought in December 2010 (back then, was its name "EDC Clicky" or still "Ra Clicky"?).Am I the only one that has no interest in calling these lights the HDS EDC? It sounds like a program started by Roosevelt during the Depression. I still call it a Ra Clicky all the time, or maybe an HDS Clicky if I am really feeling forward thinking that day. But I never call it an HDS EDC. :shrug: Just a passing thought as I was thinking about when my new Clickies will arive.![]()
I have never called mine an HDS EDC. I simply call it T200, or like your forward thinking....HDS T200.....but 99% of the time just T200.
