IIRC you can damage the reflector or LED on the old legacy lights by tightening down the reflector too much. I believe the new lights are designed so that you cannot over tighten the reflector, but do so at your own risk, I don't want my advice ruining someones light. I have also had a hard time getting the bezel separate from the reflector, but I have never removed the bezel completely. I believe the new bezel you ordered will be a bezel without the reflector, the bezel should unscrew off of the reflector assembly I believe, but it is a tight fit.Just recieved and opened the package with my new Rotary 200 enclosed. The rotary ring was a bit stiff but after a couple of twists it is feeling better already. There is one question i would like to ask though?
I have a silver bezel for this light on the way from Henry and i just went to unscrew the bezel like i do on my legacy 170T and the whole section beneath the bezel, including the reflector started to unscrew instead. Should the bezel come off the same as my legacy or will the silver bezel for my rotary come with the reflector as well?
I have tried to grip the bezel just to turn that but there is very little to grab hold of.
Help!
