I think the manual does a pretty good job once things actually click, no pun intended (seriously I just noticed I said that when I proofread my post). If you can post what your exact problem is I'm sure you will get some help. I love the programming questions/discussion on the HDS lights. Are you able to get into programming (enable programming)?
EDIT: This might help, I posted something similar in the last thread.
To enable customization: turn light on, unscrew light completely, screw light back together. It will turn on dimly, immediately click the light quickly repeatedly until it stops turning off, once it stops turning off hold the button down until the light turns off. Customization is now enabled.
To program a preset: Turn the light on with customization still enabled. Select your preset that you want to program. Double click press hold (2 clicks followed by a 3rd click where you keep the button held down). Now you can customize that preset. Click until you have the preset you want. Once you have the correct choice hold the button down and it will save that selection.
Those are the basics IMO. You can scroll backward with a double click, program all the features in the options menu, and do a few other things. I think everything comes easier once you figure out enabling customization and programming a preset. Hope that helps, if not ask away.
Thanks so much for taking the time to post this, i will have a go tonight trying to change the settings and i will report back. As you say once you have got the hang of it it will become second nature.
Regarding the throw being different on the 200 than the 170 i was always under the impression that the up to 170 lights use the golden dragon emmiter which is smaller than the 200 emmiter (XP-G?) so more of a throwy beam. Before buying my 170T i asked the same question and that was the answer i kept getting back, that the 170 is a bit better than the 200 is for throwing. When i compare my 170 to my 200 the 200 has a cooler beam and a slightly larger and more diffused hot spot than the 170.
