FPSRelic
It's too bad Henry isn't doing another titanium clicky run. With all the trouble he's had with machine shops, I can understand why.
A little clicky Bling!
Currently installing Ice Blue Trits into another Bezel for the titanium!
they are just 1.5 x 5mm trits from Bart on the market place......
I got a question for the HDS Junkies. Im always looking for well built lights to add to my rotation as an EMT. From what I read, it does not get any more bomb proof than an HDS. My question is, were there ever any HDS lights made that excepted 18mm batteries? Also, From what I hear the HDS is really thick and beefy. Does anyone know if there is enough meat on the body to bore one of these out to 18mm without losing much strength? Unfortunately all my lights are 18mm and I have made up my mind that I was not going to get special batteries for lights. Its 18mm or nothing.
Thanks for the help!
To my knowledge, the only HDS/Ra model that could accept 18mm batteries was the Ra Twisty with 19670 tube. Even with that particular battery tube, many 18650's are a tight fit. Protected cells, of course, are usually a little bit wider and may be a tighter fit. The newer (highest capacity) cells also tend to be larger, and may not fit, as well ....
As for boring, likely not recommended, as I have heard of members damaging signal wires or electronic components contained in the battery walls when attempting to modify the tube.
+1Official product request:
Ability to accept 18350 batteries.
A little plastic insert could be inserted for CR123 use to prevent rattle.
If i remember correctly, the second Twisty batch had a slightly larger 19760 tube that accept any 18650. I've just tried with all my 18650 and they all fit but I don't own any of the larger capacity new cells to test.
There was also a very rare 18650 tube made for the original EDC series (AKA ''pre-Novatac''), less than 100 were ever produced. Tim just scored one, see here...
There is also a well known hack for the existing 17670 ''pre-Novatac'' that can turned easily in a 18650 one... see here.
+1
While I'd definitely like to have the long wished for 14500 tube I think a 18350 tube would be a natural choice too.
Ah, yes ... in my mind, for some reason, I always think of the "pre-Novatac" era lights as entirely separate from the HDS/Ra (and later) models
When Henry first announced the latest line of lights, he mentioned that the heat transfer had been decoupled from the body so that he could use more exotic materials without worrying about overheating (titanium, for instance, is a terrible heat conductor). I still think a carbon fiber Rotary or Clicky would be awesome.It's too bad Henry isn't doing another titanium clicky run. With all the trouble he's had with machine shops, I can understand why.
Finally got my HDS! Absolutely awesome, couldn't be happier to wait 7 months for a light. :twothumbs
