archimedes
Archi, your pics shuld come with a warning!!! may cause drooling
Thanks ven, cheers !
NOT TITANIUM. NOT OLIVE HAIII. It was a test of NP3 nickel plating. Again, this was done about 2 years ago and has not proceeded since then. Of the things to get one's hopes up about, this currently isn't one of them.
If it's the old HAIII greenish grey anodizing... oh man... can't wait to hear more information
Ok, I found a couple of my own photos of these clips ...
These were custom shaped (bent) to size and style
What's on the head of your hds/AA model??
And included with the Ti Ra
Any further opinions on peoples preferences when it comes to clips for the clicky would be appreciated. What do guys like best and why(Standard clip, Decorative clip, Dark Sucks clip, Oveready clip)? Thanks.
Thanks for all the info, photos, and suggestions on clips guys.
I wish there was a deep carry clip available for the new clickies. Maybe I can have one custom made.
Yeah, or maybe Oveready. I would prefer steel over titanium personally with a durable PVD or DLC coating. It would be awesome to see one made similar to the Decorative ones but, be bent into a deep carry design flush with the tailcap. And, it needs a larger bend(lip) at the end so it is easier to clip on. That is one thing wrong with both of Henry's designs(Standard and decorative). They have much too small of a lip at the end which makes them hard to clip on. That is why people seem to prefer the Oveready one I think. I am guessing this design flaw might have been overlooked because Henry is not a clip user from what I hear. Maybe Hogo could bring this to Henry's attention for when the next run is made?maybe something for Jason Hui of Prometheus to look into.
I've been curious for a while, but why is it so expensive to upgrade the firmware? Is it a labor intensive and/or time consuming process? Because $45 seems a bit steep to me. I would have jumped at it a long time ago for $25 (seeing how I was one of the ones who asked Henry if he would consider offering a firmware upgrade), but that $45 price tag always makes me think twice.It may be possible. Do you know what version it is? i.e. roughly the date of manufacture? ACME threads?. The head would need to be reprogrammed, then calibrated. The cost is $45 to upgrade to the most current software. Any idea what software version is in it?
I had a light with a clip catch on the seatbelt, then fall out on a stone driveway. I never noticed it was missing until hours later. I did find it later, after having been driven over several times. Luckily it had no damage ( a HDS light ). That is the main reason I don't use clips anymore.I'm not dispariging your preference, but I've bent clips beyond recognition catching a "lip" that's too pronounced on furniture, my seatbelt, other clothing, etc. I'd rather have to lift it with my fingers if needed to re-pocket than find my light next to my seat dangling off the seatbelt. And I like having something to grab onto when drawing the light to use, finding the current clips deep carry enough. Something like the Elzetta Alpha, where half the light is hanging out of your pocket, is another story...
Yes, I suspected that the price might be deliberately unattractive.My guess is to keep every person with an HDS from sending it back in every time there's a tiny firmware update. He'd be spending all his time programming lights and never get anything else done. It's probably something he doesn't prefer to spend his limited time doing unless it's monetarily worth the effort. Running a small business myself, I totally understand if this is the logic.
I lost my favorite D10 back when they were a thing and a few years later my favorite Clicky. Neither saw either light again and I went from being a huge fan of clips to a carrier of a naked Rotary.I had a light with a clip catch on the seatbelt, then fall out on a stone driveway. I never noticed it was missing until hours later. I did find it later, after having been driven over several times. Luckily it had no damage ( a HDS light ). That is the main reason I don't use clips anymore.
That was it exactly. I asked him about flashing my firmware on a Clicky several years ago and he really didn't want to do it but relented when I asked if he could attach a charge to it in order to make it worth his while.My guess is to keep every person with an HDS from sending it back in every time there's a tiny firmware update. He'd be spending all his time programming lights and never get anything else done. It's probably something he doesn't prefer to spend his limited time doing unless it's monetarily worth the effort. Running a small business myself, I totally understand if this is the logic.
Yes, you would go to the website and purchase the upgrade. I see no problem changing the software as well, but let me confirm that with Henry on Monday.
Here is a quick and dirty way to tell what software is in your light...
Lights prior to December 2013 have the electronic lock out.
5 clicks from off candle mode: software 2.10
7 clicks from off candle mode: software 2.14
9 clicks from off candle mode: software 2.15 (this also has the 6 click from off that turns the light into pure momentary until you remove the battery for 60 seconds. This is lights after January 2015.
Candle mode was never documented but is one way to tell what software version you have.
And as a small bit of advice, when traveling to the bathroom at 0300 with a new puppy in the house, it is advisable to use a low setting on your HDS instead of the ambient light you have relied on for years. Ambient light does not necessarily illuminate the things you need illuminated. Stepping in warm and squishy puppy love does not make for a pleasant evening. Carpet is NOT supposed to feel that way.
