KiwiMark
It looks to me like it should be able to clear the olight plastic cap opening with the cap's lanyard attachment removed, but you would have to test this.
I might order a couple more of these battery holders and try modifying them.
I might as well throw in a quick review now that I have my light and have had a wee play:
The Tint:
It is interesting how you can shine two lights on the ceiling and see that one looks sorta blue and the other sorta yellow, then you take the one that looked sorta yellow and your new Jet-IIIM and shine them on the ceiling and you think that the one that looked sorta yellow now looks sorta blue - it's all relative!
The Interface:
Only 2 settings - tighten head for full, loosen for custom. Press switch for light on, click switch for light to stay on - click again to turn off. How much simpler could you want?
And yet if I compare it to my Fenix which has: tighten for full-strobe or loosen for lo-med-hi-SOS (6 modes), the Jet-IIIM has 2 modes vs 6 for my Fenix - but the Jet-III is more versatile thanks to the IBS on the custom mode.
I tested the minimum output when I got up for a drink of water at 3am - low enough so that it didn't hurt my dark adjusted eyes, bright enough so that I could see just fine.
I really like the simple but versatile UI - full power + custom setting can give you whatever you need in normal real world use.
You could set the custom output to:
Minimum - great for camping to use with night adapted vision.
Low - great for enough light, but a really good run time.
Medium - strong light, but more run time and less heat than full.
Strobe (fast) - for security work where you want full or strobe as needed.
Strobe (slower) - for use as a bike light?
SOS - change to this in an emergency to attract attention?
Whatever you need it to be the custom setting CAN be!
The build:
No comments on this really - I would notice anything I don't like, but there is nothing to notice here - everything is as it should be on a quality light so I am very happy with no negatives to notice!
The ability to tailstand is no biggie, but it is nice that this light can do it.
The batteries:
I have 18650 cells for normal use - lotsa power, lotsa runtime.
I have 16340 cells for max output.
I have CR123A cells for a backup power source.
Being able to use any of these is pretty nice!
My advice:
If you don't have this light then you should order one - this is a truly useful, functional light that will work simply and reliably in just about any situation you are likely to need a light in.
