ArcaneLogic
- Joined
- Dec 20, 2011
- Messages
- 10
I was wondering if they are reading this thread, since they put up the step-down info right after the question about it was posted here.
I've asked them the following questions, will hopefully hear back after the holidays:
Why are 16340s not recommended?
Does it use PWM?
Does it have mode memory and, if not, what does it come on in and what is the cycle order (e.g. high-low-med or low-med-high or...)?
The runtime of 2.2hrs on high - is that with or without the step-down (i.e. 2.2 hours of cumulative 600lm output)?
To clarify a comment from Animalmother - from what I understand, the step-down does NOT mean that after the first few minutes of use it will never give the full output again until a fresh battery is inserted. It DOES mean that ANY time you turn on the light (even if the battery is close to dead) it will give max output for a few minutes and then step down. So after you notice it dim, you can simply turn it off then on again to regain max output. However, doing this might overheat your light eventually. Some manufactures do have ways of disabling the step-down entirely (e.g. quickly turning it off and on 20 times in a row) but they will specifically mention that feature if a light has it.
Does it use PWM?
