Re: How to Modify 5mw Leadlight Green Laser upto 4
userx, im not sure, but your modified laser may have already had the pot mod done to it. In the case that it hasn't been done, you will not feel a click or be unable to turn the pot past a certain point. If you wish to turn the pot while keeping the laser off to reduce the risk of shorting it, turn the pot counter-clockwise a little bit and then switch the laser on. Repeat these very small turns and switch the laser on inbetween every turn. Eventually after one of the turns the laser will become very dim. When this occurs, turn the pot back CLOCKWISE a tiny turn and switch it on. If its gone bright once again then youve done it, otherwise if its still dim give it another small turn clockwise and switch it on again. Hope this helps.
