funkymonkey1111
- Joined
- Nov 8, 2007
- Messages
- 221
i've not found a huge difference in wall shining on other lights, but the differences become more apparently outside in real usage
You know, I've followed this thread for awhile and ended up buying my own M61SHO. I have an original hand engraved M60, an M61 original version and now a M61SHO. From the naked eye I can honestly say that the M60 definitely out throws the both of my other two Malkoff's, granted it has MUCH less spill. Whats surprising though is that other than tint, I really can't see difference between my M61 and the M61SHO. The SHO MIGHT have a little more even spill is all. I can't say I'd buy it again due to this. Just a casual observation here folks. Has any one else noticed this at all?
Dan
so would it matter or be very noticeable of a difference if I wanted a 'distance'/throw light if i chose an M61SHO versus an M91A?
also what does the "A" mean for Malkoff stuff?
Great!
I want this thing if for no other reason than because my 6p will be an SHO (if I could only SHO my truck into a raptor this cheap)!
I have the M61SHO in my 9p. It will not run for long in a 6p. It requires high voltage to run it, and it will not last near as long in a 6p as it would a 9p.
I have the standard M61 in my 6p...
leon2245 said:Great!
I am considering this for a weapon light. Currently, I run an M600C. Spill is adequate, but throw is what I am interested in. The M600C = E2DL on high.
Based on the LUX readings of the SHO (5-6,000@1M), it looks like it just puts out more light in the spill, but the M600C SHOULD out-throw it (I keep finding LUX 1M readings of around 6-7,000)
Is my understanding that the M600C/E2DL throws further, although with less spill, or do the extra lumens of the M61SHO somehow off-set the lower LUX readings? If anyone has compared the two, that would be great!
Thanks!
I compared the SHO with the E2DL, and was surprised at the result. At 140 long steps (didn't bring my range finder) they were close enough that I'd need a light meter to tell for sure which one put more lux on target. I wasn't able to increase the distance to the target, but I'm not certain another 50 yards would have changed the outcome. The E2DL definitely uses its measly 200 lumens to great effect. Maybe I'll start some research for a meter so I can be more certain with my tests.
Grizz
