Milky Shotgun Sweeper!
Hogokansatsukan
Tucson
Just got my Milky Shotgun Sweeper!
CreeMCE-MWD Ledil-Boom-SS IR-Reflow UCL
Direct Drive 650+ Lumens
I had Scott design me a light very similiar to the Room Sweeper, though this light would have to be able to take the abuse of repeated 12 gauge recoil as it will be mounted on a Mossberg 590A1 shotgun.
This is what Scott (Milky) made, and it's perfect, as usual.
Beam shots? You don't want beam shots, do you?
Flashlight porn to come later.
The beem is a perfect flood.
Hogokansatsukan
Tucson
OK. All coworkers are now blind or seeing spots. The beam profile on this light is similar to the Room Sweeper, however it is not quite as much flood, but let's not kid ourselves here, it is a flood beam. There is no hotspot in the beam, but it "appears" to be brighter than the Room Sweeper as... oh heck... here are some picture so you can see:
Room Sweeper
Shotgun Sweeper
Room Sweeper
Shotgun Sweeper
The closeups are at about a foot from the wall. The Shotgun Sweeper is a flood, without spill, if that makes sense. The Room Sweeper is a flood that has a hot spot with tons of spill.
Can't wait to mount it up on the A1 tonight as it will have a tape switch.
milkyspit
New Jersey
Hogo, glad you like it. Heck, I wanna see these in-action weapon-mounted photos, too! :naughty:
Hogokansatsukan
Tucson
Here it mounted up and ready to "rock and roll".
This photo just gives me an uneasy feeling...
As soon as I get out in the desert, I'll get some live fire photos.
LightWalker
USA
Room Sweeper
Shotgun Sweeper
Room Sweeper
Shotgun Sweeper
That's an interesting banner you have, it doesn't seem to be too popular with Homeland Security though.
http://www.worldnetdaily.com/index.php?fa=PAGE.view&pageId=97374
I guess it's too Patriodict for them. :mad:
LightWalker
USA
It seems it's not hard to be considered a terrorist these days.
goldenlight
Right here....
I spend far more time on firearms forums than I do here.
I've NEVER seen optics mounted on a Mossy.
Nice looking set-up, though; that light is really AMAZING.
Hogokansatsukan
Tucson
Does not work good for skeet, however here's a 25 yard target with 9 pellet 00:twothumbs
And here is the other custom ammo I feed it:
.69 hard cast round ball at 1500fps. Will penetrate 1/4 inch steel.
These in the pic have been dug out of a burm.
Hogokansatsukan
Tucson
Just finished my sling for it.
Of course, the shotgun's name is "Mjollnir" which means "Crusher" and just happened to be the name of Thor's hammer:hitit:
Monocrom
NYC
It's great how all you have to do is swap out the tailcap, and you get the best of both worlds.
Mdinana
That's a kick *** light! So far I've been using a regular ole 6PL, and it's been doing fine for me... though I'm not a cop!
milkyspit
New Jersey
Is the inside of the head as uneven as it looks, or is that an optical illusion?
Monocrom, perhaps Hogo could tell us more definitively, but for my part I believe it's an optical illusion based on the way the camera was angled to take the photo. It certainly wan't uneven when it left here, I know that! Also wasn't covered in dust as in Hogo's photo, but I attribute that to a dusty environment on his end or maybe already having seen some use in the field.
The reflector is a Ledil Boom Medium, which is hexagonal in shape on the outside and very slightly oval on the inner surface... that might have something to do with the photo as well. It's also worth mentioning that the way the reflector was designed there is a small amount of play even when seated on the emitter... it doesn't look like that's involved here, but I suppose the reflector could have shifted ever so slightly during shipping or field use.
Really think it's just the camera angle AND (if you look very closely) a reflection on the front surface at the right side of the reflector. Follow the outer rim of the reflector counterclockwise from the bottom point and you'll see what I mean. :shrug:
