kj2
Klarus ST2C now available at HKe
interesting...
Interesting gadget .Uses Micro USB port and because it is not built in the flashlight you can carry it and use it only when that's needed.Screwing on the head end will eliminate the need of dual-layer tube body.Also will not affect the lenght of the flashlight!
So, there will be two new klarus lights on my watch/to-buy list
next to the Nitecore MH25
pretty good flashlight! suitable for a very wide range of applications so naturally it doesn't excel in some areas. forward clicky tailswitch is the MASTER on/off. side button changes modes or puts it in standby. if tailswitch is off then side button doesn't do anything so goodnews no accidental activation here
only 4 brightness levels but they appear very well and evenly spaced-out to the human eye. it may not seem like it judging from the raw numbers on the specs sheet but the seemingly big jumps in the ST11 brightness levels are IMHO very well chosen for the vast majority of typical usage scenarios. very reminiscent of a Quark's spacing, but instead of 5 levels you only get 4. yes just like Quarks the ST11 has proper low modes.
it isn't obvious from the pictures but it doesn't have a typical tailcap, instead the head is unscrewed to change the battery.
takes long 70mm cells. flat tops no problem.
ceiling bounce on a light meter shows ~26% stepdown after 5 minutes.
but despite the driver being moved to the head it still uses PWM in typical Klarus fashion. it's a sufficiently high frequency so it isn't distracting.
So if the clickie switch fails you have to replace the whole body?
Sent from a cellphone using tapmyfinger
copper star
Cool - was it difficult to open-up the head?
