Re: Osram Halostar IRC lamps
There are two product ranges: Halostar 111 and Halostar 111 IRC.
The 6V assembly is without IRC. There is no 6V Lamp in the IRC range.
The IRC are all rated 4000h.
My Osram
Sorry for the bad news...
jashhash said:
Wattage:35
Voltage:6
Diameter:4
Height:
Base:G53
Lamp life:3000
This IRC lamp assembly by Osram is 35 watts at 6 volts. Wonder if this would be a good light to run at 7.2 volts from 2x Li-Ions. If 36 lm/watt could be achieved at 7.2 volts then were looking at something like 1620 bulb lumens driven at 45 watts in a 2D form factor. I'm not sure if this IRC lamp assembly has the IRC bulb coating or if it uses the metal cap covering the bulb to reflect back IR heat. If these bulbs are IRC coated then Perhaps Osram might consider selling us the bare bulbs.
My Osram
