AFAustin
IIRC, at one point, Peak planned to also offer an Eiger in Shasta/Baltic size. Don't know if that came to pass.
I have an Eiger and 2 Baltics. No way you can use the Eiger head on the Baltic unless you do some major work. The head diameters are very different - the Baltic is much larger.
The Eiger fits on Matterhorn bodies - I know, since I have a couple of Matterhorns with extra bodies.
As an aside, can the Eiger cope with "rough" use? The Matterhorns sure can. I don't abuse lights and none of mine have failed. I just wondered how sturdy the Eiger will turn out to be.
Yeap, my bad guys - I should have said that Curt says he can make Shasta-version Eigers, which will work on the Baltic =) Which would be cool, as I heard that there are N-cell Nimhs you can get somewhere. Would be interesting!
Hm, you're the first person I've heard of who uses the battery contact adjustability. Which I always thought was a cool feature but one I never would need.
However, I'm beginning to wonder if it is really useful with respect to using a 10440, since the lengths might be different compared to alks...i.e. if I wanted to use an Eiger head on my Peak AAA brass lug body. Hmm...
Ah, I see, cool. Thanks for the info RC.
The momentaries, I don't see them on the site - but does Curt still make them upon request? Are they pretty useful?
If it hasn't been used for a few moments, it's very hard to turn the head of my Eiger. That thing is quite tiny and my grip isn't just firm enough. I got the gold plated version, probably the most "slippery" one. Not a real problem, but you have to get used to place your fingers right, if you try to turn the body together with the head, no light will come out... :sigh:
I know that o-ring problem already from my Quark AA-2, VERY hard to turn the first time, fortunately that head is larger and has better grip because of the knurling.
I like a pretty fast twisty action on my Peaks, and most of the time that means sanding the o-ring a bit. Works like a charm.
AF- what grit paper do you use?
