Phaserburn
That's cool. Was it hard to do? Is the light on all the time?
I have some thoughts on this. For a driver with a physical switch to have an "off timer" they need a capacitor to run the MCU and latch the last setting as "saved" (say) ~2 seconds after the light is switched off. The 105D driver in the convoy does not have a capacitor (as far as I can tell). As a result, the latch occurs as an "on timer". Imagine that an "event loop" starts in the MCU and loads the last saved brightness level. It then calculates (and saves) the next brightness level (L M H). If the light is turned off within the 2 second timer then the "next" brightness level remains saved. If the 2 second timer expires then the current level is saved (and therefore available) the next time the light is turned on. Now imagine that 2 seconds have passed. When you tap the button the MCU can't distinguish (without a capacitor anyway) whether the light has been off for 0.5 seconds or 2 days when it comes back on. The first tap from an "on" state reloads the current brightness and starts the 2 second timer. The second tap starts again but loads the "next" brightness setting that was saved before it could be overwritten during the prior 2 second cycle.
Does that make any sense?
How can you check if its Alu or SS?
Use a magnet.Alu is not magnetized.
That's looks amazing. How much did the parts cost and how long did it take to mod? Would you consider modding tail switches for us members who don't have the skills to do it?
With a good battery the driver will pull 2.8amps, you'll likely need an IMR 18350 to see this in the smaller light. A regular ICR 16340 probably won't see the same amp draw.Can anyone tell my why the light below is claimed to be 1k+ lumens when it appears to have the same specs as the one in this review? I'm new to most of this.
https://www.fasttech.com/products/2222905
I like the red. Love the mod causing tail to light with flashlight off. Would be nice with triple 219b or hi cri xm-l2 or hi cri XP-G2. Does it have any heat protection?
As for the lumen claim, 2.8amps is probably 1000 led lumens. Out The Front is a likely different story, as there will be losses. That said, almost all of the 'big' premium brands don't pull more than 2.8amps, so it's the same ball park figure.
Word of warning, with the small battery 16340/18350, runtimes will be very low at high output. Convoy normally offer different numbers of 7135 chips on their drivers. The 7135*8, i.e. it'll have eight 7135 chips is the 2.8amp driver. You may find a lower spec driver will simply work better. Max output will be lower, but runtimes will be much improved.
If you are using 18650's and the longer body, then it's less of an issue, as an 18650 typically has 2500-3100mAh+, but a 16340 or 18350 are more like 600-700mAh.
On a personal note, I prefer the S2+ over the S2 model. And you can get an 18350 (accepts 16340 too) adapter tube for them:
http://www.banggood.com/18350-Batte...S2-Blue-And-Red-LED-Flashlight-p-1009722.html
I was looking for something pretty small to just throw in my pocket, runtimes aren't a big worry for me since I usually use low and small bursts of high when I need it. As for batteries I got 2 efest imr 700mah 18350's.
Reason being for this light is that I already ordered a k70 so my big light needs should be filled with that hopefully and then this little S2+ to throw in my pocket. Thank you for answering my question so quickly!
Sounds great. I especially like user set temperature control. I am very very conservative about heat. I basically don't want a flashlight to get hotter than bath water ever.I'm building this current run (my first) with triple 219c's but you're not the first to mention a Hi CRI triple 219b and that's definitely an option. I've got one myself, but not in these hosts. And yes, the lights I'm building have heat protection. I'm using the newest version of the BLF FET+1 driver, the one from the X6/X5 group buy that just finished (tiny25-based with Bistro firmware). It has temp monitoring and step-down, and its user-programmable so the end user can adjust the temperature themselves.
But that's kinda off-topic here. I don't mean to derail this thread and turn it into my own sales thread. I'll start a new thread when the appropriate time comes.
