RobertM
Re: Surefire Aviator release date?
There is no "white version." All of these new Aviators have four total modes (2 color and 2 white). In the case of amber, you get amber low, amber high, white low, and white high. When you have the head turned to Amber, clicking the tailcap turns on amber low and an additional press will switch to amber high. When the head is set to White, clicking alternates between low white and high white. You always have a low mode and high mode, whether it's the color LED or white LED is determined by the bezel position. The middle position on the bezel, Off, locks the light from accidentally activating either LED.
Hopefully this explanation helps.
Someone please help me understand- only the white version has white high and white low correct? It's not amber-low, then white-high? From the specs I was expecting amber-low 5l, amber-high 20l only, but in pictures I see a "WH" and "AMBER" positions (on the same light?)... and an "OFF" position, which I assume that's like a lockout, since there is already a clicky. If anyone understands and can help with my confusion here I'd appreciate an extremely dumbed-down explanation for me.
Wish they could have squeezed in machining costs for a little bit of head crenelation, like the new E1B. But if I'm missing something and this aviator does have a bright White and low amber in the same light, I'd rather have this one.
