I am a newb to CPF and am building a balancing setup for charging with my e-station BC6 charger.
I am in need of 4 pairs of magnetic leads like those previously offered by LuxLuthor with the purchase of cells from him.
How can I go about obtaining these ?
Revisions Made.
this would have to be a great one
http://www.hobbyking.com/hobbyking/store/__14856__Parallel_charging_Board_for_6_packs_2_6S.html
Im glad i found this thread as ive had my Hyperion 720i charger about 2 months now and mainly just do test cycles for capacity and rely on my Pila to charge cells since i have nothing set up for mass cell charging.
But i do have a question, How well do these cradles setup with the balancing leads handle discharging?
Does it just do a basic discharge, Or is it just as reliable as a single cell discharge cycle when using the balancing leads?
My main goal is to cycle many of my Li-Ion cells which tend to increase in capacity when new after a few cycles.
Im not sure which way i want to go on building a way of using my balancing leads as i do prefer cradles over magnets, But each has its good and bad points. I do know im not to fond of just hooking them in series or parallel and charging multi cells in that manner as you loose control of everything since the charger just sees one large battery.
Thanks for all the work in doing up this thread and pics as it should make my build easy, Especially i was just never gonna build a setup for multi cell balancing. Now i can get the full use of my charger and can see up to 6 cells graphs all running on my laptop as the charger does its job.
Looks pretty similar to http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=15237 which I have ordered with my 208B and should arrive Monday or Tuesday. I don't normally parallel charge, but I figure there will be times that I want to get more batteries charged in a hurry and being able to charge 2 or 3 or 4 at once couldn't hurt. I have plenty of those T connectors and alligator clips to make more charging leads as required.
Mine is the same sort of thing - I'm going to keep my board intact because I have various LiPoly battery packs with the balancing leads already attached. But I've ordered some JST-XH extension leads - I figure I'll just cut the end off that I don't need and solder some ring terminals to suit my battery setup. You can get extension leads in 2-7s in packs of 10 for a few dollars from here: http://www.hobbyking.com/hobbyking/store/__9735__JST-XH_2S_Wire_Extension_20cm_10pcsbag.htmlMy goal is to build something from a 7S balancer set of wires and just use what i need. But im not sure what set of wires should be used to start from.
If i need a certain plug can you point me to one that is exactly what i need so i have no confusion.
same thing, just with deans plugs (t connectors) just makes sure the batteries voltages are close
Do i need to use the board, Or can i cut the wires going into it and build my leads from that?
