Wattnot
The water leakage problem, which was a tiny amount in the battery tube only, NOT the head, was quickly addressed and a conversation stopping solution was posted. Eagletac will send you a fix in the mail. By now I'm sure the fix is being done at the factory on the newly manufactured units.
That being said, the IPX8 standard, from what I've read on this board, is a loosely applied term with multiple definitions. Most of the lights talked about on this board carry the IPX8 designation which (don't quote me on the exact numbers) means it was tested at a depth of 1 meter for 30 minutes? Or is that 30 meters at 1 minute? Either way IPX8 does NOT make it a dive light. Not even close. It means if you drop it in the pool or show off to your friends by putting in the fish tank for a few minutes, you'll be fine.
I am thinking of purchasing this light but waterproofness (IPX8?) is a critical factor. It cannot be simply "splash proof" as some lights are due to the nature in which I'll use the light.
Anyone here can shed some light? From EagleTac's webbie they mentioned nothing about waterproofing.
