Thanks.
Can you try out the tailcap button option to see how well that works?
After hearing all of the horror stories about stripped screws and what not, I just decided it wasn't worth the hassle of putting the tail cap on.
Any particular reason that you are drawing a pistol with about a pound dangling from your wrist? I can't imagine that a boat anchor can help your draw. Why not use the light with your left hand and put the lanyard around your left wrist?
Because I feel most comfortable with the light in my right hand and I'm not counting on using it in a situation where I count on it being a major problem. If I'm investigating a bump in the night, I won't be using the M2. I'll be carrying the M2 when hiking and activities such as that. I'm much more prone to encountering a dog/coyote/rabid shrew in that situation and therefore the weight isn't a major concern of mine. Not bragging but I can draw fast as hell and to be honest, the extra weight affects me minimally in a competition of "draw and fire" against a buddy of mine.
Would it affect me in the heat of the moment if something were truly happening? Possibly but its not a major concern of mine at this time.
One last thing, the reason I carry it on my right wrist with lanyard and let it drop is also because I don't carry it in a position to makes itself readily transitionable to the Harries technique. I carry it like you might carry a maglight when on a long walk. There isn't an easy way to switch to the appropriate hold using just the left hand. However, when letting it drop and dangle from my right hand it is extremely simple and more of a gross motor movement to then sweep in with my left hand to take the light up into the proper hold.
I won't say there isn't a better way because often there is for someone else. It just seems to be what works for me. I suppose given time to decide what I want to do, before going and searching an area, then yes, I'd likely just carry it in my left hand and draw my weapon into a position sol carry or just carry low but thats not the kind of situation I'm likely to be in when hiking.
