Mainly for music
Yep that sounds like the Nautilus alright :twothumbsB&W's flagship line was around $30,000 for the front left and right speakers:green:..... I'm serious.
+1 I agree 100%B&W are my favorite speakers and that's currently what I've had for 15+ years.
+1 again, you guys and me think alike and it's AWESOME :rock:$1500 will get you a great music setup. I would focus on 2 channel unless 75% of your listening is concert dvds or something like that.
The sub is somewhat optional but I would recommend separating your bass driver from your 2 main speakers. <----very important
I might even spend $1k+ on the speakers and skip the sub until down the road.
For 2 channel in your price range you're going to want most or all of this stuff:
2 main speakers
1 subwoofer
1 2 channel amp
1 Pre amp
The separate pre amp/amp is optional if you runout of budget after speakers. The sub is somewhat optional but I would recommend separating your bass driver from your 2 main speakers.
So many varieties and tastes for audio. Alot like lights only alot more expensive, especially for quality gear. Go different places and listen to as much as you can. Cost is only 1 factor. Size, weight, do you care where it's made? Service/warranty, resale value, looks, brand name, lots of things to think about. Do you listen to it loud or not so loud? A great speaker will still sound crappy if the amp is not so great. Make a list of your likes/dislikes. You can generally do okay with used gear if you know what to look for. Alot of pro gear would serve you well and most of it is rack mountable too, handy when moving things around. I'm just trying to give some things to think about, have fun and enjoy it. Few things are like a good sound system.
DO NOT, I repeat, DO NOT skimp on the cables. Along the same lines as splurging a bit on the floorstanding fronts, a good set of cables will last a lifetime. Take a look at the Kimber website to read the introduction. They're worth every penny.plus the cables and installation...@#$%
Illum_the_nation just ignore the watts rating on any speakers you buy.
Also since you asked for brute honesty, $1500 probably won't get you what you want. Orchestra has ALOT more low end than you think. I would say plan on spending 3k at least. Sorry about that. At least 1000 watts on low end. But I want to be honest. Mark
with most subs you can tell where it is placed, and if it is not right in the middle it is annoying and unnatural.
I'm sorry, but that is simply misinformation. I'll stake my yearly salary on the fact that 10 people couldn't A/B the most expensive MIT cable from lamp cord with a P value of less than 0.05.DO NOT, I repeat, DO NOT skimp on the cables. Along the same lines as splurging a bit on the floorstanding fronts, a good set of cables will last a lifetime. Take a look at the Kimber website to read the introduction. They're worth every penny.
That's because most subs are tuned too high, have too much upper bass, and are crossed over inappropriately.A small amp is more prone to clipping at higher volumes and more likely to destroy your tweeters, but unless you want your windows to rattle a decent brand amp of say 2x 50-100 real watts should do fine.
As for speakers, try to get full sized ones ( I like a closed system better for it's better controlled bass), and don't use a sub, with most subs you can tell where it is placed, and if it is not right in the middle it is annoying and unnatural.
Since most of the listening you are doing is in stereo and not surround skip the surround, it seems to sound nice at first, but after a while you will notice how unnatural it really sounds... :thumbsdow
A trained listener, under the most ideal circumstances, would have trouble telling the difference, because it's only marginally greater than the background noise. Actually, even specialized equipment would have problems. Speaker cables matter very little - what matters are CONNECTIONS because for most people they consist of hand-twisted exposed strands, that oxidize like crazy. What's the solution? Buy gold-plated plugs, and solder the cables to them, then use adhesive heat-shrink to seal the site. That'll do more for your signal path than anything else, for something like $1 per terminal.I was just trying to give the argument that when you've got a powerful and expensive engine in your car, and you've also got some really nice wheels and tires, why put a cheap driveshaft or axles between them. I'm not saying that you have to buy the most expensive cables out there, just that they should be decent and not some crapola no-name overseas brand.
