KiwiMark
Has anyone tried to calibrate the volt-meter to -.15v to trick the charger into charging the 4.35v Samsung ICD-18650-30a?
Good idea, but the calibration doesn't let you change the voltage by that much, you'd be pushing to get as much as -0.05V with the calibration for a maximum of 4.25V.
Some chargers offer more settings - the iChargers can charge to 4.30V, so if you calibrated one of them to -0.05V out and then set the LiPo charge to 4.30V you would get 4.35V, you could then set the LiIo charge to 4.15Va and you would get 4.20V on that setting and you could set the LiFe charge to 3.55V and get 3.60V with that. That would work really well for all Li-ion cells.
On the Accucell, even if you could alter the calibration by -0.15V (which I am certain you can't), then your Li-Io setting would become 4.25V instead of 4.10V and your LiFe setting would give you 3.75V instead of 3.60V - so you'd need to recalibrate every time you charged a different type of battery.
