Re: vinhnguyen54 Run 5 Cree XML P60 Drop In 1000 Lumen Warm, Neutral, Cool White
Hi Vinh,
First, nice job on your first ever YouTube video demonstrating the foil wrapping which was very informative. If you were truly nervous, it really didn't show.
Second, although I think I understand that in addition to the 8 listed pre-programmed options on the Ultrafire drivers, you can also set the amperage of each individual mode, is that correct?
Third, since I know nothing about programming drivers yet and I've wondered about the possibilities of home-programming custom P60 modules per customer request, without regard to the extensive work involved or the cost, is it even possible to change the pre-programmed mode sequences listed, offer memory on only certain modes, or hide the flashing modes into a seperate grouping from the constant current modes, (but still have the flashing modes available), in the way that a stock flashlight could be programmed like an ArmyTek or HDS? For example, on your newly aquired Ultrafire 10 mode "high current/low voltage" driver, instead of keeping the pre-programmed modes in Option #1 of: ML-M-H-ML-M-H+4 Flashing modes, could those 10 modes be reprogrammed for instance to: Firefly-Moonlight-L1-L2-M1-M2-H1-H2-Turbo+2 Hz Blink?
Last question, considering and taking seriously your priority of "safety first" when using your high output modules, if you set one of your new P60, XM-L high output drivers with a high mode at 5.6A, what battery suggestions and precautions would you offer for safety.
Cheers to you and best wishes for even greater success in 2012.
-John
