Since when is any Ti light practical ?
People buy them for the pretty factor. Aluminum lights are the standard for many reasons. Ti makes since on fighter jets, not flashlights IMO.
Bud
I found these useful points on Russtang's site.
Properties of titanium
- Highest ratio between strength and density of all metallic materials.
- Extreme mechanical and thermal loading capacity.
- Extreme tensile strength - stonger than steel but 42% lighter.
- High corrosion resistance, particularly against oxygen.
- Extremely bio-compatible because of it's tissue compatibility and it's elastic attributes.
- Titanium is inert and therefore completely corrosion resistant.
- It does not react to salt water, sunlight, or any body chemistry.
- Titanium is 100% hypoallergenic.
- Titanium is the preferred material for surgical tools, implants, pacemaker cases and other internal casings.
- It won't react with any part of the body, making it a great choice for even those persons most sensitive to other materials. When a person has an allergic reaction when wearing a pair of gold or silver earrings due to the alloys, it is recommended that they switch over to titanium earrings.
- And unlike silver, Titanium will never tarnish!
- Titanium does not become magnetized.
- Titanium can only be worked with extremely hard tools.
- Titanium has an extremely high melting point of 1800 degrees Celsius.
- Titanium is as strong as steel, but 45% lighter.
- Titanium is 30% more elastic than steel.
- Titanium is resistant to salt water, perspiration and acids.
And from the man himself (McGizmo):
"It's real simple. Ti is the
most low maintenance and dependable metal I can use for a flashlight. Its
longevity will insure that I will be the one to fall out of love or need before it becomes compromised or no longer able to function for me. I can use and abuse a Ti light hard and put it to bed wet. It may show it over time but then so do I! Titanium is a noble metal on the galvanic scale and further, I am a stickler for all exposed metal to be of the same to insure
galvanic corrosion is impeded anyway.
Ti is a
fast healing metal and in no time, even after some abrasion, it will sport a
protective oxide film. HAIII is a great and durable film on Al but it does not heal or replenish itself; leaving the raw AL to grow a soft oxide. The oxide film on Ti is
electrically conductive. The oxide film on Al is not. I recall in one of these "Why Ti and it's just hype" threads a number of years back where I went into my shop and grabbed a stick of Al off the shelf as well as a stick of Ti from the shelf. I used an ohm meter to measure the resistance of I think it was 2' in length. Without scratching the surface of either metal, the Ti had a measureable but
low resistance whereas the Al read as an open circuit until I scratched the meter probes through the oxidized surface. As I recall Ti was getting a beating for having a higher electrical resistance than Al."
More discussions
here and
here on the advantages of titanium over aluminium for flashlights.
It's evident Al has the advantage of light weight, heat conductivity and lower cost, but Titanium is used not just because it's "pretty".
