CUL8R
Wow! Received this light much faster than I thought I would. The 4 main levels are well spaced and burst mode is bright even in daytime. I compared this to the only other 18650 headlamp I have, a Nitecore HC50. The nitecore is much more solid (machined from one block of metal). This means it needs all three of its included straps to hold the head from bouncing when you walk. The Fenix is not one piece and nowhere near as heavy. It feels fine to me without using the top strap - no bouncing or movement. Very light for a high powered 18650 headlamp (comparatively). The reflector is also deeper than the one on my Nitecore. This means that while the light is still hugely floody, it throws better than the nitecore. It definately has a more distinct hot spot, or is more focused than the nitecore. In my opinion, this makes it a much better all around light than my HC50 which is a good all-arounder in it's own light (excuse the pun)! Very good flood with enough throw to see some distance (maybe tonight I can find out how far). Oh, and the 30 second burst mode seems longer than I thought it would - it provides time for a good look around before dropping back to whatever level you started at. And yes you can go directly to burst from off if you want. This is definately my new backpacking headlamp! Great light Vinh(and Fenix)!!!:twothumbs
