Hi again,
Ok, if you want me to look over the equations you'll have
to be more specific...that is, i need to know what values
of vsense you're using for both 2v and 3v inputs.
And wait a minute......
You were saying that the tables i posted were not when the
battery runs down, and i had said that they would show
what happens if you set the output for a constant current
for three values (2,2.5, and 3v) of input of the original
non-regulated Zetex 300 circuit, but i think it does in
fact show what happens as the battery runs down in the
CCR-2 circuit also. This would happen because the resistive
bias circuit can maintain the output current to within about
1.8 percent (theoretically) of original setting if the
values of the upper and vsense resistors are chosen
correctly.
For example, lets assume that using a particular inductor
value L requires the following relationship between Ipk
and Vin in order to maintain 350ma output:
Vin=3 Ipk=0.51675
Vin=2.5 Ipk=0.64455
Vin=2 Ipk=0.8175
This means if the value of the sense resistor was CHANGED
for each level of Vin the output would hold a steady
350ma dc current.
Now given the same table:
Vin=3 Ipk=0.51675
Vin=2.5 Ipk=0.64455
Vin=2 Ipk=0.8175
if, using the bias circuit, we could find two resistors
(upper resistor and the sense resistor) of constant value
that causes the circuit to change it's Ipk exactly as
the table shows (the requirement for constant 350ma out)
that means we'll get the same results as if we had adjusted
the sense wire length each time.
Make sense?
It just so happens that i've been able to find values
that hold the current to within 1.8 percent of the set
point, which is pretty darn good i think.
As i stated in (an) other post(s), i thought it wasnt going
to help to try to adjust all three resistors, because two
of them work as a ratio together rather than control
anything individually (top and 5.1 ohm resistors).
This turns out to be proven once again, as adjusting the
5.1 ohm resistor and optimizing for the other two doesnt
reduce the percent error over the three input levels
(although now that i think about it i could try using
more levels (like 2.1, 2.2, etc., up to 3v) in the
optimization process.
Let me know your thoughts on these things...
Take care,
Al
