Eagletac lights with XP-L HI (High Intensity) plus others!
Mr. Tone
Illinois
Hello fellow flashaholics, I recently asked Tod from Illuminationgear if he knew if Eagletac was going to offer the new Cree XP-L HI (High Intensity) LED in any of their lights. For those who don't know, the new XP-L HI is a domeless version of the regular domed XP-L, which is now called XP-L HD (High Density). This new LED is exciting for many of us who love throw and have had lights customized with de-domed LEDs. Anyway, Eagletac is really good about offering multiple LED options for many of their lights and this will be no exception. Tod from Illuminationgear gave me permission to post this new info on CPF. Illuminationgear is a great dealer and I highly recommend them, I have had many great purchases through them and their customer service is top notch. Here is the info Tod gave me below. Eagletac is also offering a new 3500ma 18650 capable of a 10amp draw as well.
EagTac/EagleTac/SporTac is
"pleased to announce six brand new flashlights. We also obtained very limited quantity of CREE XP-L HI V2 LED which will be installed in the G25C2, T25C2, and SPORTAC dual level P60 brass drop-ins. New EAGTAC 3500mAh high discharge 10Amp Protected 18650 (Sanyo NCR18650GA) is also available. All new products are available to ship (to Dealers) before 6-20-2015. Website and product images will be available later this week.
New products:
M30LC2
- Replaces M25C2, features all-new LED module upgrade design, led upgrade module compatible with M30LC2C. Uses T25C2 user interface. Come with Base and Kit model. Available in NW.
- LED: XM-L2 U3!
- LED lumen/ANSI lumen: 1260/1030
- 2-4*CR123A/1-2*18650 (kit w/extension tube)
M30LC2C (M30LC2 Compact)
- Replaces M25C2, features all-new LED module upgrade design, led upgrade module compatible with M30LC2. Uses T25C2 user interface. Features Triple LEDs design with deep reflectors. Available in 3*XP-G2, 3*XP-E2 color green, 3*XP-E color red, Triple 219B CRI92 NW, and more. Come with Base and Kit model.
- LED: Triple XP-G2 S2 / Triple XP-E color Green/Red / Nichia 219B / Edison 395nm UV
- LED lumen/ANSI lumen: 1200/950
MX30L3
- Replaces MX25L3, features xh-p50 LED w/ diffused dome for nice beam, all-new user interface w/ dual switch design (no twisting head). Four stage battery level report, allow turn on at MIN or MAX level. Come with Base and Kit model.
- LED: XH-P50 J4 CW
- LED lumen/ANSI lumen: 3300/2750
- 6*CR123A/3*18650
TX25C
- all-new model, turbo head (T size like TX25C2) mini CR123A flashlight. Highest output in the market from single CR123A that offers 580 LED lumen. When using RCR123A, max LED lumen is 695. With the included body extension tube, user can use two CR123A that yields 1050 LED lumen. Side switch LED sign with three stage battery report system. Single side signal switch system with user interface like the Sportac headlamp. Magnetic tail-stand tailcap with pocket clip.
- LED: XM-L2 U3!
- LED lumen/ANSI lumen: 600-1100/520-950
- 1-2*CR123A/1*17650 (comes w/ extension tube)
D25C Clicky Ti 2015
All new look Ti 2015 titanium limited edition with XP-L HD LED.
- LED: XPL V5
- LED lumen/ANSI lumen: 485/349
- 1*CR123A/1*RCR123A
D25A Clicky Ti 2015
- LED: XPL V5
- LED lumen/ANSI lumen: 220/159
- 1*AA / 1*14500
XP-L HI V2 LED limited run:
CREE XP-L HI is the "dome-less" version of the regular XP-L (now called XP-L HD). The HI version offers two times more lux output reading compared to the regular version while maintaining similar lumen output.
G25C2 with XP-L Hi V2 LED (very limited qty only)
T25C2 with XP-L Hi V2 LED (very limited qty only)
Sportac dual level P60 all-brass drop-ins with XP-L Hi V2 LED (very limited qty only)
New protected 18650 3500mAh:
EAGTAC 18650 3500mAh protected li-ion 10A discharge (Sanyo NCR18650GA, cell made in Japan)
This is currently the highest capacity 18650 li-ion battery in the market. With high current discharge 18650 cell (rated 10Aamp) and brand-new highly efficient protective circuit that kicks-in around 12Amp, this 3500mAh easily become the best protected 18650 money can buy."
FYI - new ET alphabet soup announced a couple days ago:
New products:
1) DX30LC2
- Features side switch (no twisting head) and forward clicky switch in D25 size, 5 levels, allow turn on at MIN or MAX level, four stage battery level report, C3200L circuit
- LED: XPL HI V3 LED
- LED lumen/ANSI lumen: 1160/905
- 2*CR123A/1*18650
2) GX30L2R diffuser
- SPOT + DIFFUSER output in one flashlight, dual switch design (no twisting head), built-in rechargeable port with new waterproof rubber cap, new charge cable included, new balanced R19 7.4v battery pack included, four stage battery level report, allow turn on at MIN or MAX level. C6800 DIFF circuit. Comes with Base and Kit (w/ upgrade R25 pack, UL charger, more) models.
- LED: XPL HI V3 LED + LED array
- LED lumen/ANSI lumen: Spot: 1920/1450, Diffuser: 910
- 2*18650 li-ion battery pack
3) GX30A3 diffuser
- SPOT + DIFFUSER output in one flashlight, dual switch design (no twisting head), four stage battery level report, allow turn on at MIN or MAX level. C3900L DIFF circuit.
- LED lumen/ANSI lumen: Spot: 1330/980, Diffuser: 1000
- 3*AA (support 1.2v NIMH, 1.5V alkaline, 1.7V lithium only)
4) MX30L4XC
- Four optics, 12 LEDs design, 25% shorter than the regular L4, dual switch design (no twisting head), four stage battery level report, allow turn on at MIN or MAX level. C7000HV circuit. Comes with base and kit version.
- LED lumen/ANSI lumen: 4800/4030 or 4000/3210
- LED: 12* XP-G2 S2 or 12*219B D220
- 4*18650 or 8*CR123A
LED Upgraded products:
1) SX25L3 with XHP50 J4 LED, 3300 led lm/2750 ansi lm
2) MX25L4 with XHP50 J4 LED, 4020 led lm/3250 ansi lm, new lower price
3) M30LC2, XPLHI V3
4) TX25C, XPLHI V3
5) D25C Ti, XPLHI V3
6) D25A Ti, XPLHI V3
7) G25C2, XPLHI V3
8) T25C2, XPLHI V3
9) SPORTAC P60 two levels drop-in LED module, XPLHI V3
CelticCross74
Fairfax Va
Re: New Eagletac lights with XP-L HI (High Intensity)
looks like the domeless XP-L G25C2 will be my next ET!
recDNA
It will be exciting to read reviews and see the beamshots. I especially like small flashlights so I'll be curious to see how much throw is improved in a small head.
Mr. Tone
Illinois
I edited the title to show that there are also new Eagletac products that are not based on the XP-L HI. These new models look good and I bet the new triple reflector M30LC2C will be popular.
kreisl
Re: New Eagletac lights with XP-L HI (High Intensity) plus others!
Mr. Tone
Illinois
That's because there aren't any yet, unfortunately. Eagletac's info on my first post states that images and specs should be available later this week.
Mr. Tone
Illinois
Eagletac's website now has pics and technical info on all the new models. I will try to put them in the first post when I have the chance.
WhitedragonBC
Limited editions? This should be the new standard for the M25C2 and S200C2 (or their replacements).
Mr. Tone
Illinois
I couldn't agree more. Those lights are designed for throw so they should go all out like Olight. Maybe they will offer it in these replacements at some point.
markr6
M30LC2C with triple Nichia 219 :)
jon_slider
Eagletac-D25-AAA-Review lumen output sequence 6-32-68 with N219B
"There is no sign of pulse width modulation (PWM) at any output level on the D25 AAA. There is however a circuit pattern visible on the lower outputs on my oscilloscope (which is uncommon on many lights). "
L3-Illumination-L08 lumen output sequence .09-3-30-90 with N219B
"There is no sign of PWM at any output level, on any model. The L08 is current-controlled. "
Ryp
M30LC2
M30LC2C
MX30L3
TX25C
recDNA
I like pocket sized lights. 1 x 18660 with small head or 1 x imr123. I wonder how much the new xpl will increase throw with a head of 1 inch or less?
Mr. Tone
Illinois
Thanks for posting the photos, Ryp!
Amelia
Does anyone have a link to the specs of the T25C2 and/or G25C2 with dedomed emitter? I'm curious about the throw...
markr6
TX25C looks nice too! Surprised it doesn't support an 18650!
And check out the UI on the MC30L3:
[h=3]Operations[/h] Basic operations:
  • Turn on the light at MAX output by pressing the BLACK button switch. Turn on the light at LOWEST output by pressing the WHITE button switch
  • To turn off the light anytime, press and release the BLACK button switch.
Advanced:
  • For MAX output momentary on, press and hold the BLACK button switch for immediate output.
  • To switch between different brightness levels, press and release the WHITE button switch when the flashligh is on.
    (For example: if you want to turn on the flashlight at the 3rd level, just press and release the white button switch three times from off.)
  • To enter hidden auxiliary levels, press and hold the WHITE button switch when the flashligh is on.
  • For instant MAX output - at any output level, press and hold the BLACK button switch. Release the button to return to previous level.
  • For instant Strobe output - at any output level (even) off), double press and hold the BLACK button switch. Release the button to return to previous level (or off).
